The phone does not start right, it remains blocked in the written MetroPCSWhat does not work?
Calls?
Texts?
Emails?
Also, what phone do you have and what model number?
I have an LG Leon H340N. Yesterday I installed the firmware from the official site, now the phone will reboot continuously.If you want help, you really need to provide more information. We don't know what phone you are using. We don't know what you were trying to do. Your post is very vague.
After giving the device proper make and model information please provide if the device has been rooted or not.
What did you install.. A .kdz file?I have an LG Leon H340N. Yesterday I installed the firmware from the official site, now the phone will reboot continuously.
No KDZ file, I installed with LG Mobile Support ToolWhat did you install.. A .kdz file?
How did you install it.. LG flashtool?
Now your device is stuck in a bootloop which I've had before and got pass that by doing a hard reset.I installed from a MetroPCS KDZ file, the phone would crash at startup, so I downloaded LGMobile Support Tool and downloaded back to the original firmware. Now the phone reboots constantly.
I have done so many times the hard reset, but nothing.Now your device is stuck in a bootloop which I've had before and got pass that by doing a hard reset.
How can I do?Ok did you completely flash your device before downloaded back to the original firmware
I hope to resolve the problem, there is not take it anymore.Gentleman, I'm not familiar with the Leon, but most of the Metro LG phones have (at least in the past they have for the Motion and others) had a method of flashing back to stock. Is there a method for this phone? If so please direct @Torring to that method.
Sent from my LG Nexus 5X using Tapatalk
I'm stuck in step 8, where I find the .txt file?
I downloaded the firmware from a website by entering the IMEI, now what should I do?So I just noticed that you said it was H340N. That's for O2, EE, Vodafone and 3, not MetroPCS. I don't know if there are any physical differences between your phone and the phone that MetroPCS put out, but you probably shouldn't have tried to flash a Metro firmware onto your phone. You should try and find a firmware for your specific phone model.
