smokelog rollback
ensoniq10
Hi everybody.
What a friendly forum :).
I need some help guys, and was wondering if you can help..
I downloaded from the market a smoking app called smoke control..
Loved it.. really helped me cut down on my filthy habit..
Recently updated it, and its changed the whole layout.. Really dont like it at all...
I'm using an HTC sensation, but I've realised Ive got the old version of this app on my HTC desire....
Is it possible to get the old version which i prefer from my Desire, onto my Htc sensation...
Many many thanks in advance..
Martin..
Welcome to AF :D
If you have it installed on the Desire you should be able to use an app like Astro file manager and make a backup of the apk file from the Desire on an SD card. Then take the apk and move it to the SD on the Sensation and sideload it, you would need to uninstall the version on the Sensation before trying to sideload it.
If that doesn't work you could always contact the dev and see if they will just send you the apk or make the old layout available in a future update.
Hi. Thanks for the reply.. just tried that, but just my luck its an app that can't be moved.. even tried a move to SD app, but still no luck...
I sent the developer an email over a week ago, but still no reply...
Is there anyway I can do it through my computer?.. only seem to be able to get to the SD card... Really really want this app on my sensation..
Many thanks in advance..
Martin..
