SMS Encrypto
jwilke101
SMS Encrypto -
Simple SMS Encryption App for Android.
If you are in a business where secrecy is an issue, but, you need public cellphone text messaging, then this is the app for you!
Simply and quickly send encrypted messages, and only share the password with the recipient to decrypt and read.
New! Fake Message - Convince people that you sent them a message that they never received, or, that you received a message that they never sent.
This app is not meant to replace your existing messaging system. It is meant to be a small, quick and powerful message encrypting app..
How it works:
1) Start App
2) Choose Compose Message
3) Enter Phone num, Enter Message, Enter Password, press send.
4) If the recipient replies back with an encrypted message, then Choose List Messages from the main menu..
5) Select the message to decrypt, enter the password, then, press Decrypt.. You will see the human readable message.
Note: The message data is encrypted on the senders phone and sent the whole way to you as encrypted text.. even as it flows through the phone towers and wires... even as it flows past prying eyes such as competitors, spouses.. even stalkers..
none of them can see it..
This app writes nothing to any phone memory or sdcard. Nothing written, means, nothing hacked.
It only sends out encrypted text.
Does not store any contact or password information. If it's not stored, then it can't be hacked.
All messages are contained in one sms message. There are no multi-part messages. This eliminates message confusion.
Due to the bloat after encryption, there is a 60 character limit to the message length.. this is a fair trade off for the super strong encryption: Base64-Encoding compliant with RFC 2045.
You and your associates will use this app like a tool. It was developed as a personal tool and wide spread use amongst myself and friends made me decide to bring it here.
Keep your passwords strong and stay thirsty my friend. ;-)
https://play.google.com/store/apps/details?id=com.sms.encrypto
This app encrypts the data on the senders side and then sends it encrypted, so it can't be intercepted along the way.. Other apps just encrypt the messages after they are received and read by you. That means that they can be intercepted before you get a chance to encrypt them.
New features in Version 6..
Encrypt any message in your inbox and save it as an encrypted message in your inbox..
It's as easy as long press.. enter password and then press the button.
Safe and Secure!
Update version 8 is now available... Now allows you to encrypt and save messages from your sent text messages. Plus, new cool colors.
