Help sms generic network erros help please
ok. I had made a gold card and installed clockworkMOD but had issues and didn't do anything else to my htc desire from the provider ntelos in the U.S....left it that way for a few weeks.
Everything seemed to work fine, then yesterday, i attempted to send a photo with messenger on the phone. First I got message was corrupt format or unsupported format or something. Then I just started getting generic network error when i attempt to send a photo to someone on a message.
I assumed that it was just a network problem so i didn't think much of it...had worked just the day or two before no problem.
Then I decided to mess with my phone a bit because i wanted to get froyo...so I used clockwork mod to reset factory/clear personal data and flash CDMA/USCC Pre-Rooted 2.2 RC3/Final rom to my phone....everything seemed to work ok but I continued to get the same error on sending mms. I am able to send and receive txt messages just fine, I can receive pictures, and my internet works on the phone through both mobile network and wifi.
I searched the forum and found on person who said go to app management>>>messenger>>>and clear data...which I did but got same error.
I have also found threads where they say that apn settings need to be modified; however, when i attempt to follow those instructions the option to alter apn settings is not there....not in the version i'm running; under mobile network anyway.
I considered flashing to the backup i made before i went to the pre-rooted rom; but as you will recall this error started before I flashed that rom.
****I have since flashed the rom back to a restore point i made some time ago...i notice that my mms "connection settings" wich are greyed out are different now that i've done the recover with
MMSC: http://mms.ntelospcs.net
MMS proxy: (not set)
MMS port: (not set)
MMS protocal: WAP 2.0
Any help with this issue is greatly appreciated unfortunatley shortly after I got this phone I did something to change the ntelos logo screen to the white htc brilliant...whatever.....before I got a restore point running so i don't think i can take it in and get help.
if i reboot my phone the mms connection info goes blank...all some functions can send text and receive photos/txt but cant send photo.
***have installed a third party app for messaging that allows me to set apn's I've tried various mmsc designations...same results.
I suppose there is no way to get it back to stock for service is there? any rom's from ntelos htc desires cdma's out there?
