SMS international messaging
  • Start date Start date
A
Android Question
Guest
I seem to have a problem sending messages internationally. It seems to work fine locally. Is this some sort of setting that I need to adjust? Help pls????
Do you mean text message (SMS) or multimedia message (MMS). If they work fine locally the first thing you should check is if you are putting the right country code f.ex. Great Britain +44........ If sms isn't working even then you should contach your carrier. For MMS there has to be a special contract between the carriers and there is a pretty good chance that they don't have that. But still you should contact your carrier for more info.
