SMS notifier
m0s3s
I downloaded a app called chompsms to replace the default sms program on the Android platform. But every time i receive a txt or something it will go to both. Is there anyway to disable the default one and keep the one I downloaded instead of getting notification in both programs?
Also I know that this is not related in this thread, but when does the g2 come out in the USA. I saw that Wal-Mart (of all places) will have it but says July. Just seeing if there was any information about more specific release dates. And also would it be wise to get a g2 from Europe and flash it with a US carrier?
:D
:D
You have to go into the default app and turn off the notifications.
Could you explain how to turn off the notifications? I also just downloaded ChompSMS and really like it but the double notification is annoying meee.
I have gone into my settings and the notification area but I guess Im missing it because the only option I found is to mute everything except alarms and music and I dont wanna do that I actually wanna turn off the G1's built in txt messaging notifications.
Thanks D:!
if you still need it here it is
go into the message app (the default one) ...click the menu button, go to settings, then go down to notifications and uncheck it
