Help sms popup help!
glockjs
well i can't find any setting to fully turn off sms notifications only to make the sound silent. the issue im having is sms popup seems to pull the sound i had a day ago vs the notification sound i currently set. even if i use the setting to make it silent and use sms popup notification they both go off.
this wouldnt be an issue if i could just fully turn off the phones notification and use sms popup but i can't find anything in settings. am i missing something?
suggestions?
thanks in advance.
VM Samsung Intercept
suggestions?
thanks in advance.
You should be able to turn off the notification for your text messaging app.
Open it, then menu, and uncheck notifications.
Now, with that being said, i recommend you turn off that notification, uninstall sms pop up, and install Handcent.
Handcent is a much better messaging app that has it's own pop up.
So you wont have to fight with 2 different apps to try to get them right.
