ben1122a
Hello,
I am currently running CM7 on my motorola triumph. I am a heavy texter, so I like to be able to respond quickly. Currently, I am using chompSMS, but I have also used handcent, gosms, SMS popup, and Glowfly. I have encountered a problem with all of them.
Here's what happens. Using either the CM7 lockscreen, or widgetlocker, the SMS popups will show up when the phone is locked. However, after the screen turns back off, the popup seems to become 'hidden' under the lockscreen.
Basically, if the screen is off, the popup turns it on, and it is over the lockscreen. But, when the screen is turned back off while the popup is still there, the popup is no longer there untill you UNLOCK (draw pattern) the phone. Then it is there on the homescreen.
So, I would like someway to keep the popup on top of the lockscreen, even after the screen is turned off.
any and all help is appreciated.
try my small app Smart Notify with popup windows and reminder
