you might look at your stock sms app to see if it is grabbing text as well as the Go SMS app. The problem might not be with Go SMS at all. ... just a thought. Below is a link to the area where we discuss Android applications. You will want to check into that area and ask for help there. Best of luck to you and thanks for joining these forums. Android Applications - Android Forums
