snapchat bluestack android
Wise11
hi
i have error in snap chat on pc in bluestack how can i solve it ? for android
Oops!
You’re using a version of Snapchat or operating system that’s no longer supported. Please upgrade your device’s operating system and update to the newest app version to use Snapchat. Thanks!
Upgrade to the latest version of Snapchat or your iOS or Android operating system.
please help
Have you gone into the play store, updated to the newest version, and rebooted your phone and then pc?
no this happen on pc when open snapchat on android smiluator sofywtre bluestack on PC
Oops!
(on mobile works good)
I guess it's something Snapchat themselves have decided, like they're just not allowing their service to run on something that isn't a real Android device. And there's probably not a lot can be done about that, other than you contacting Snapchat and enquiring about it.
i want solution
Think you'll need to contact Snapchat for that, as it's their app that apparently won't run in a virtual environment. Maybe it's a deliberate feature decision by Snapchat, to only run on a real physical Android device, like a smart-phone.
One thought though, doesn't Snapchat require a camera to work, and the Bluestacks software won't provide that hardware item. Also I believe Bluestacks provides a rooted Android environment to apps, Snapchat won't usually run on rooted devices AFAIK. And something else, Bluestacks is built to run on an Intel or AMD x86 processor, maybe Snapchat only supports ARM CPU architectures. So there's possible reasons as to why it may not work.
