Help Snapchat Oh no!...
SavageRobot
Android Expert
Anyone else had this error before? I have followed the link in the error and tried those options, nothing. I have opted out of beta, nothing. Back into beta, nothing. Tried older APK, nothing. Running out of options now :/
It happened just after updating to MM but doubt that has anything to do with it, would imagine internet would be riddled with this error if it was that.
LG G4, rooted.
Here is a screen of the error
It's the just the sign in process
There's an xposed module which helps with this iirc.
Also, it's just the sign in process so if you have a backup of an older version using Titanium/Helium, you should be able to restore that and have it work no problem.
I actually just figured that out. I made a new account and it let me create and stay signed in. But then if I log out and back in it blocks me again. So what is it that Snapchat not playing with? Is it the fact it's rooted? Don't suppose you know which module this is? I figured Titanium will come into play here and restore data if I can actually get in it in the first place.
It checks for xposed, I couldn't find a module that worked to cloak it, had to get 9.17.00 or whatever version apk from apkmirror and restore a backup. No trouble since then. Snapprefs also has a workaround to the check for xposed.
Yea problem is that I can't log in to backup log in details. Downloaded snapprefs but can't find the hide xposed option.
