Hey I'm kinda new here but I couldn't find a thread that addressed this problem.
I'm using Snesoid on my Droid X and it works great but the problem I'm having is that I can't use more than 2 buttons at once. I know Multi-Touch is made for having two buttons used at once but is that as far as it can go?
I'm up to a part in Chrono Trigger where I have to use 3 buttons at once as a password but the third button wouldn't register so I was wondering if there was a way to fix that.
Thanks
Thanks
Change your key mappings back after you're done.
