Easilyamused
and the dock icons are really small; much smaller than the home screen icons. even using higher res icons they are "shrunk" down. is there any way to make them larger?
Nice ninja.
I've had a play and you can get the icons in the dock the same size if you only have 4 icons. If you have 5 they get shrunk to fit them all on
It took me a little while to figure that one out. If you go to preferences, application settings and tick auto fit icons it will edit the sizeof the icons to fill the gap.
