Accessories So, I was searching for a compatible wall charger and cable...
You definitley should check out monoprice.com, I picked up 4 usb cables, a usb wall plug, car usb adapter and threw in a 15ft hdmi cable all for less than $15.
If you do just make sure you pick up the right usb connection (look at the zoomed pics to be sure).
and found this.
Barnes & Noble - NOOK AC Adapter and USB Cable Kit - BNRP5-850-1
My daughter has a Nook and had to buy another wall charger. I'd mentioned that I'd been searching for a similar item like the one that came with my Incredible and she showed this to me.
I tried it out with my INC and it looks to be completely compatible.
AND it's only $15.
Could you please write here in the forums what the specifications are on the actual adapter ?
Should say something like 5v and something mA ?
