So.. this might sound very odd.
  • Thread starter Thread starter Member 2135452
  • Start date Start date
M
Member 2135452
Guest
But after installing nova, and I usually head over the settings, and both of my edge of the screen tends to blip in and out, there is no third party in it, except for icon studios... I need to run a few test in it too, any sugesstions?
what do you mean by edge of the screen blip in and out? the edges flashes? not exactly sure on what your issue is.
Like the screen cut will be much narrower, when I slide up and set it in my system settings most of the time..
I notice it for a nano second.
