On Slashgear's review, I didn't see any secondary mic on the device's top, as it is there on international SGS2. Seems like Samsung increased the screen size and battery capacity, but took away some small but good features.
Note: Slashgear's review probably has the most (too many practically) photos of anything so far. There is a second hole right above the volume rocker button.
Why or why do so many whine instantly without doing some real research? It's almost like everyone is paranoid and likes to have something to cry about...even when not true?
Isn't that hole for lanyard strap?
LOL. If there is only one hole for a lanyard strap, how do you get the strap anchored? (And that's a very tiny hole!)
On the other hand, if you look at the photos with the back cover off, you can see a hole that might connect to the hole on the outside of the phone.
Did the original European Galaxy S II have a lanyard strap? If so, you might be correct. But you suggest that the European S II did have a second mic, correct? I'm confused.
Update: And where is my lanyard strap? (Would anyone actually use it?)
It is for a lanyard, that hole is far to big for a mic, the back-side of the phone has the other end for the lanyard strap to go through.... Also one review, I believe the Wirefly one says something about a lanyard strap hole... maybe one of the hands-on videos, I've watched far too many videos lmao... oh wellLOL. If there is only one hole for a lanyard strap, how do you get the strap anchored? (And that's a very tiny hole!)
Yep it is a lanyard strap hole even though its one hole. U lift the back cover off and there is an anchor underneath. the original epic has the same.LOL. If there is only one hole for a lanyard strap, how do you get the strap anchored? (And that's a very tiny hole!)
