burntorangefan
I plan on using ADB on day 1 and rooting to remove bloat. Who else is in???
I already have everything ready to go. As soon as the box gets here I'll turn it on, sign in, and ROOT!!!
I'm currently on a rooted HTC Incredible. Used Clockwork mod method so I'm unfamiliar with the root procedures for Moto devices. Any chance you can steer a Moto noob (but not a total noob!) in the right direction?
Thanks!
turbo,
Not sure what you mean by the "clockworkmod method." Most Incredible rooted users that I know (and I rooted my buddy's Inc as well) used unREVOked to one click root it.
Without getting into too much detail, I'd advise using Google to get ADB and the associated SDK installed. Having said that, there are one click apps that work for Bionic, D3, etc that it's been reported on DL will work here as well. To be honest, setting up ADB takes longer than the actual process.
Sorry for the confusion. Yes, unREVoked is what I used to root it; Clockwork is the Boot Recovery, but in any case, it was a pretty easy process. I'm vaguely familiar with ADB and SDK; more research will be required. I'm in no hurry to root, although I do like having a rooted phone.
With this phone in particular there might, and I emphasize the word might, be a benefit to waiting on rooting the device. It's anticipated that early next year Motorola will be pushing ICS onto this handset. Since a lot of people will likely be waiting anxiously for ICS, there may be more developer activity on the Droid Razr after the update.
Rooted as aoon as a method was posted.
DooMLoRD v2 ROOT zergRush XDA Thread
Szadzik, was this the method you used? If so, any issues?
I rooted to try to get the FM Radio to work. Still in the process of hopefully getting it to work. Unlike the Bionic it doesnt come with anything FM Radio related or if it does I cant tell.
I tried using Root Explorer but I must need the permissions set right, will try adb way later. Right now I need to let it charge up some more.
CorrectoRooting in itself doesn't usually prevent OTAs, right? .
