SocialJogger Problem?
ridz1ba
Just tried out the Acer SocialJogger app on my brand new A500 tablet. The Facebook portion works fine & I was able to log in and browse the feeds. The Twitter portion, however, gave problems - I simply cannot log in. Everytime I try (the username & password is correct BTW) I get an "Invalid signature. Please make sure the system time is correct." message. BTW, the system time IS correct. Anybody successfully using SocialJogger with Twitter?
Just figured it out! Go into date and time settings. Pick select automatic date and time. This should allow you to log in to twitter a it just worked for me! Hopefully this works for you a well. Let me know, ok? :)
On my Iconia A500, I can use Social Jogger to access Facebook, but not twitter. When I try to login with the correct user name and password I get the error message 'Unknown exception (-100)'. I have tried force stop and disable/enable in Applications. I have turned my clock to automatic. I have tried to find HTTPS security control that was mentioned on another post without success. Any thoughts please?
