mhrf90
OK so I installed TWRP through the Playstore app in the wrong partition. Soft brick/No OS. I was now stuck at bootloader. I have managed to get TWRP working (2.7.1) I tried two other versions which were not loading (2.8.7 and 2.7.0) I suppose due to my hboot being old. Now I'm in TWRP but it tells me it can't mount internal storage. What do I do? I can't mount nor wipe anything other than cache and SD card.
EDIT
Out of desperation decided to try every single TWRP version. 2.8.1 is the most recent version that runs and it fixed the internal storage issue. I tried flashing CM13 but it says it needs HBOOT 3.18 or 3.19 while I'm running 3.16. Now I need to find how to update HBOOT. Things are looking great!
EDIT
