Root Soft bricked my phone
I think I may have soft bricked my phone after changing the font via font installer. I used the framaroot method in order to root. Turning on the phone results in a freeze at the t-mobile screen during reboot. I'm a bit of an android noob so I don't have any back ups. I was able to go into recovery mode and I did a factory reset. I'm not sure if that helped out or if it made things even worse. The screen still freezes on t-mobile during reboot. Is there anyway that I can go about fixing this? Thanks!
Tell T-Mobile that when you went to update the phone it froze? I don't think you can fix it atm since there is no working recovery.
