Help Soft key sensativity
Not that I know of, I don't see anythin wrt that under setting. I'm not sure if you already know, but when pressing the soft key, press above the icon a bit. I naturally do this, so I find the soft keys pretty 'sensitive'.
Wow! I tried touching just above the icons like you said and it works great! HTC FAIL
Yes, a lot of people complained about it (other threads). Best part on where the sensitivity is located on the buttons...you have a higher chance of 'accidentally' hitting those buttons when you're using the screen. :mad:
Disclaimer: I don't have a nexus one yet but I've seen a million youtube videos of them being unboxed, reviewed etc..
These are touch-sensitive buttons so they work better if you make contact with the pad of your finger. If you push above the button with the tip of your finger, you're accidentally pressing the button correctly with the pad of your finger, as intended :D
