Software problem?
On my 16 GB of internal, I have 1.4 GB available. On the external SD card I have 4.9 GB available. I have dumped a bunch of pictures etc and moved some more to the SD. And I decided to activate Knox. Still getting it. How much available space should I have?
ok keep us posted on what worked for you.
Right, I went to apps > Google > hit force stop, hit disable; the version installed was reverted to the factory version without updates. Re-enabled that, rebooted, and it worked. Will not reupdate until the next time an update is offered. Thanks, all, for the assistance!
