Software to SD Card
HTC Desire
Sorry if this has already been asked but I tried searching "transferring", "transfer" "install" "sd card" "sdcard" and couldn't find what I was after... anyhow...
Can anyone tell me how I can transfer my installed software onto my SD card. I have no space left on the internal memory but 6.79GB on my SD Card free! I keep getting updates saying I can now install things onto the card but don't know how to go about doing this?
Is there a way to set it up so that when you download new apps, they install onto the SD Card straight away?
On another note, I have a virgin contract and no update to Froyo. Have given up on it really as I am quite happy with the phone as it is (except for the storage issue).
Thanks for any advice
Andy T
Download apps2sd, it's a free app
It will give you a list of apps that can be transferred to your SD card, and will give you the option to do so. Not all apps can be installed onto the SD, but more apps are adapting to that daily. In the meantime, the apps that you can transfer to your SD should free up your internal memory.
