Hi all,
Just been setting up my new lg optimus 3D (i haven't rooted it or done anything 'dodgy' with it, just installed astro from the market and imported my contacts from an external sd card).
When i put my sim in a software update came up in the notification bar, so i updated and once it reset it's gone to the android system recovery <3e> screen, the options are:
reboot system now
wipe data/factory reset
wipe cache partition
wipe cache partition and package recovery
wipe nv dynamic partition
When i reboot it just comes back to the same screen, I haven't tried any others as i don't want to factory reset as it's taken me a little while to get this far. any ideas what the best option is? If i don't hear back soon i'll just factory reset it and report back but if you know what even happened that would be great. My network is Orange in the UK,
Thanks
reboot system now
Thanks
