Does anyone know if there is charger for galaxy s3 (I9300)?
Solio's Bolt, Solar Charger supports S2, I suppose they won't have a problem charging S3.
Unfortunately that's the only Solar charger I know of, I have never used one, nor am I planing on using one, so I can't be of any more help![]()
I don't recommend solar chargers with build-in battery !
Charging the phone with such a solar charger is not the problem![]()
The above mentioned solar panels haven't a internal battery. They works as USB charger (5V output voltage) and they are able to charge a phone or tablet directly and properly.Hi
Does the solar charger need an internal battery? Is it not able to convert to electricity in the charger and save it directly in the phone battery?
Thanks
