Root {solution}LOW MIC. VOLUME TRANSFER THE BASEBAND UPDATE
Thanks, I just installed 213 baseband. Was exasperating because I'm on Win7 and needed 7CDC drivers. I installed all drivers but kept on getting "EBL must be injected" error repeatedly like niksss. Couldn't figure out what I was doing wrong. Then I followed shivakiran's instructions to the letter and it worked. Trick is to click "Start USB" while your phone is in BP mode, then remove battery+cable, go back to BP mode and reconnect cable. This worked immediately.
Let's see how 213 is compared to my previous old 733 baseband.
Howdy everyone i have been facing very low mic volume in all roms
even my earlier baseband was not able to resolve the problem
so here is another baseband update package try it
chinese are saying this the best baseband till now but every week or so new baseband arises ,i will update the thread if better basebands
FIRSTLY BASEBAND OF A PHONE MEANS IN SIMPLE MANNER THE NETWORK CAPABILITIES OF A PHONE
WHAT I AM GOING TO PROVIDE YOU TODAY IS TESTED ON 2.3 ROM WILL IMPROVE:-
1)NETWORK SIGNALS
2)main improvement in low mic volume
3)IMPROVE BATTERY BACKUP(CURRENTLY 8-9%% )
5)FAST RESPONSE FROM NETWORKS
6)VOICE QUALITY AND QUANTITY IS effected IN THIS BASEBAND
GUIDE BEGINS
DOWNLOAD THE FILE
baseband update_3.zip - 4shared.com - online file sharing and storage - download
EXTRACT IN ANY DIRECTORY
Will see two installation files
INSTALL THESE 3
FlashUSB
FTDIDriver
ProlificDriver
NOW EXTRACT TBW780121_7674_WCDMA_V0902
AFTER INSTALLING AND EXTRACTING OPEN
FlashTool_E2
Open, select OK will appear
CLICK ....
NOW LOCATE THE EXTRACTED FOLDER TBW780121_7674_WCDMA_V0902
IN THE FOLDER SELECT ALL 4 FILES .FLS FILES YOU SEE
DO NOT SELECT OR DO ANYTHING WITH SAM FOLDER
Select four fls extension file to open
And then click NEXT to enter, there will be
Then click
NOW POWER OFF YOUR PHONE POWER ON IT WHILE PRESSING VOLUME DOWN BUTTON (YES VOLUME DOWN)
THE PHONE WILL GO INTO BP MODE
NOW IMMEDIATELY CONNECT CABLE
SOMETIMES THE PHONE IS NOT DETECTED JUST TRY IMMEDIATE CONNECTIONS
IT TOOK ME 4 TIMES TO CONNECT THE PHONE
do not forget to say thanks
appz if u have original baseband of a85 i.e. 733 plz upload it. I have to get my phone serviced.so plz reply quickly.
could upload it, only when I clicked Start USB without connecting the phone.
Then Pressed Power Button and Volume Down.
Waited for the Green Screen.
Den connected the phone..
This all to be done in 30 secs..
As the Flash utilities time out is set to 30 Secs....
Tamseel.
Best way to update your baseband ! For sure !
