solution to black screen and space bar after cursor problem
My wife and I both had the spacebar problem... often when typing, it would not leave a space between words even tho you pressed the spacebar. The space would end up at the end of the sentence! It was driving us crazy! While hunting for a solution we turned off the LG IME. Presto! spacebar problem gone. You also loose the auto suggest function but I can live with that because it just seemed to slow the phone down while messaging anyway. Sure hope LG has a fix for it soon because I'm sure some people really like the auto suggest function.
