theperfectpunk
If you are not able to send files on your micromax A70 using bluetooth.
Then possibly the reason behind it is that you need to pair both the devices, either by using the other device or the Micromax A70.
In Micromax A70 it could be accomplished by :
Open Menu -> Goto Setting -> Wireless and network settings -> Bluetooth Settings -> Scan For Device -> Long Touch The Device Address Below Scan For Device -> Choose Pair
After performing the above steps you would be able to send files to the device you paired using bluetooth
Or You Can Use The
Bluetooth File Transfer
app by
Medieval Software
available on android market.
Or You Can Use The
app by
Medieval Software
