lens pirate
Member
1. Grab and install the Market app for the phones. This will install Market 3.44 that is for PHONES but it works. You can up date your apps.
2. Go into the manage application settings and you should see two market icons.
3. Delete data cache for both entries. Then choose uninstall updates on both entries.
4. Reboot.
5. On your computer go the the Android market web site and go to the Market application page. Choose to install it to your tab.
6. Wait a few mins and you should see a notification that you have a market update pending. Allow the install.
7. Market should now work with Tab version 1.10 Mine does.
I hope this helps!!!
4. Reboot.
