consultant
After carefully reading reviews between Samsung S3 and HTC One X I was excited to get the One X due to:
- Better looking interface (Sense)
- Better screen in bright light
- Auto text-wrap when zooming on web pages
- Nicer build/feel
Then come to find out AT&T only offers 16GB version! Argh! Looking at my iPhone 4, I'm using just over 16GB of storage for audio alone! (I have a large music library). I thought maybe the S3 would be okay, but I've ready horror stories about battery life, like One X, so I figure if S3 doesn't have better battery life, I really need to see about getting around the 16GB limit and get the phone of my choice.
If I can't change carriers, I'm thinking the only solution is to get the International Version and give up 4G LTE capability which I don't need as I'm okay with 3G speeds, then renew my contract with a phone from AT&T that I can get the most profit from reselling to make up for buying the International HOX. Swap the SIM card and done?
I know other solutions might be:
- Compress the audio files and don't sync songs I rarely listen too. I'm an audiophile. While my library isn't 256-320kbps files, they are very high quality. I tend to use m4a as it has better compression anyway.
- Move songs to cloud. This means I would need an unlimited data plan and would not be able to play songs if I didn't have a 3G or WiFi connection. Not a good option.
Can't believe this powerful of a new phone only comes in 16GB (on AT&T) Completely PATHETIC.
- Nicer build/feel
