Root *SOLVED* 3g supercharger issues
socal6107
ok so this i what i got... read the post about boosting metro 3g (even though its only evdo) and followed directions exactly and no matter how hard i try i cant get this damn script to run... it just stays saying running but no menu, changes or anything no matter how long i let it run. i am using busybox v.1.18.2 and script manager ads, and the simple IP tweak anyone else had this problem? or any suggestions? i cant stand the UL and DL speeds
Your using smanager to run the script SU right? Anyways.. Update the su binary from the su app in settings. If you actually scroll you can find it
you should also update your busybox. if you look on the first page of the V6Supercharger thread there is a busybox 1.19.4. if you are using the supercharger or kak you will need this.
