Apps SOLVED: App help
brggames
Howdy. Just getting into android programming and have ran into a snag. My program opens with a splash screen then goes to a menu screen with 3 buttons. The 2 buttons I've coded so far work, but the target class of one crashes. I know the buttons work because I had it go to a temp class I made and it went there fine.
Also, when I only have the basic code in the target class it works.
package com.brggames.dquest;
import android.app.Activity;
import android.os.Bundle;
import android.view.Window;
public class temp extends Activity {
@Override
// TODO Auto-generated method stub
requestWindowFeature(Window.FEATURE_NO_TITLE);
setContentView(R.layout.hall1);
That works, but the next one does not work. It crashes.
import android.media.MediaPlayer;
import android.view.View;
import android.widget.Button;
public class hallOne extends Activity {
MediaPlayer bclick1;
Button bForward1, bBack1, bLeft1, bRight1, Bpause1, bPlayMusic1;
@Override
bclick1 = MediaPlayer.create(this, R.raw.bclick1);
Button bLeft1 = (Button) findViewById(R.id.bLeft1);
bLeft1.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View v) {
bclick1.start();
Button bRight1 = (Button) findViewById(R.id.bRight1);
bRight1.setOnClickListener(new View.OnClickListener() {
@Override
bclick1.start();
Button bForward1 = (Button) findViewById(R.id.bForward1);
bForward1.setOnClickListener(new View.OnClickListener() {
@Override
bclick1.start();
Button bBack1 = (Button) findViewById(R.id.bBack1);
bBack1.setOnClickListener(new View.OnClickListener() {
@Override
bclick1.start();
Button bPause1 = (Button) findViewById(R.id.bPause1);
bPause1.setOnClickListener(new View.OnClickListener() {
@Override
bclick1.start();
Button bPlayMusic1 = (Button) findViewById(R.id.bPlayMusic1);
bPlayMusic1.setOnClickListener(new View.OnClickListener() {
@Override
bclick1.start();
and here is the xml file
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout
xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent">
<ImageView android:layout_width="fill_parent"
android:id="@+id/imageView1"
android:src="@drawable/hall1"
android:layout_alignParentTop="true"
android:layout_alignParentLeft="true"/>
<Button android:id="@+id/bPause1"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:layout_alignParentBottom="true"
android:text="Pause"
android:layout_alignTop="@+id/bPlayMusic1"
android:textStyle="bold"/>
<Button android:id="@+id/bBack1"
android:layout_centerHorizontal="true"
android:text="B"
android:layout_width="48dp"
android:layout_height="48dp"
android:textSize="24dp"
<Button android:id="@+id/bForward1"
android:layout_above="@+id/bRight1"
android:layout_alignLeft="@+id/bBack1"
android:text="F"
<Button android:id="@+id/bRight1"
android:layout_above="@+id/bBack1"
android:layout_toRightOf="@+id/bBack1"
android:text="R"
android:focusableInTouchMode="false"
android:focusable="false"/>
<Button android:id="@+id/bLeft1"
android:layout_toLeftOf="@+id/bBack1"
android:text="L"
android:focusableInTouchMode="false"/>
<ImageButton android:layout_height="wrap_content"
android:src="@drawable/play"
android:id="@+id/bPlayMusic1"
android:layout_alignParentRight="true"/>
</RelativeLayout>
Any help would be appreciated.
Remove "Button" from in front of each of the lines like this:
Make it this instead:
Because you've already declared the buttons here:
Still crashes, here is the modified code
import android.content.Intent;
import android.view.Menu;
import android.view.MenuInflater;
import android.view.MenuItem;
Button bForward1, bBack1, bLeft1, bRight1, bPause1, bPlayMusic1;
int rNumberB;
int rNumberF;
@Override
@Override
bclick1.start();
@Override
bclick1.start();
@Override
bclick1.start();
Thread playgameF = new Thread(){
public void run(){
try{
// get a random number from 1 to 8
rNumberF = (int) Math.floor(Math.random()* 8 + 1);
//Switch Case decides which random hall to go to
switch (rNumberF){
case 1:
//go to hall 1
startActivity (new Intent("com.brggames.dquest.HALLONE"));
break;
case 2:
// go to hall 2
startActivity (new Intent("com.brggames.dquest.HALLTWO"));
break;
case 3:
// go to hall 3
startActivity (new Intent("com.brggames.dquest.HALLTHREE"));
break;
case 4:
// go to hall 4
startActivity (new Intent("com.brggames.dquest.HALLFOUR"));
break;
case 5:
// go to hall 5
startActivity (new Intent("com.brggames.dquest.HALLFIVE"));
break;
case 6:
// go to hall 6
startActivity (new Intent("com.brggames.dquest.HALLSIX"));
break;
case 7:
// go to hall 7
startActivity (new Intent("com.brggames.dquest.HALLSEVEN"));
break;
case 8:
// go to hall 8
startActivity (new Intent("com.brggames.dquest.HALLEIGHT"));
break;
catch (Exception e) {
// TODO: handle exception
e.printStackTrace();
finally{
finish();
playgameF.start();
@Override
bclick1.start();
Thread playgameB = new Thread(){
public void run(){
try{
rNumberB = (int) Math.floor(Math.random()* 8 + 1);
switch (rNumberB){
case 1:
//go to hall 1
break;
case 2:
// go to hall 2
break;
case 3:
// go to hall 3
break;
case 4:
// go to hall 4
break;
case 5:
// go to hall 5
break;
case 6:
// go to hall 6
break;
case 7:
// go to hall 7
break;
case 8:
// go to hall 8
break;
finally{
finish();
playgameB.start();
@Override
bclick1.start();
@Override
bclick1.start();
//Menu code below
public boolean onCreateOptionsMenu(Menu menu){
super.onCreateOptionsMenu(menu);
MenuInflater miMenu = getMenuInflater();
miMenu.inflate(R.menu.menu, menu);
return true;
public boolean onOptionsItemSelected(MenuItem item){
switch (item.getItemId()){
case R.id.restart:
startActivity (new Intent("com.brggames.dquest.RESTART"));
return true;
case R.id.options:
startActivity (new Intent("com.brggames.dquest.OPTIONS"));
return true;
case R.id.quit:
finish();
return true;
return false;
I comment out everything and it works. I doubled and tripled checked my AndroidManifest.xml, and for the life of my I can't figure it out. As I said, I'm new and may be missing something very simple. Here is the code with the stuff commented out. the menu code at the bottom works perfectly (the restar button isn't coded yet).
//import android.media.MediaPlayer;
//import android.view.View;
//import android.widget.Button;
int rNumberB;
int rNumberF;
@Override
@Override
bclick1.start();
@Override
bclick1.start();
@Override
bclick1.start();
public void run(){
try{
switch (rNumberF){
case 1:
//go to hall 1
break;
case 2:
// go to hall 2
break;
case 3:
// go to hall 3
break;
case 4:
// go to hall 4
break;
case 5:
// go to hall 5
break;
case 6:
// go to hall 6
break;
case 7:
// go to hall 7
break;
case 8:
// go to hall 8
break;
finally{
finish();
playgameF.start();
@Override
bclick1.start();
public void run(){
try{
switch (rNumberB){
case 1:
//go to hall 1
break;
case 2:
// go to hall 2
break;
case 3:
// go to hall 3
break;
case 4:
// go to hall 4
break;
case 5:
// go to hall 5
break;
case 6:
// go to hall 6
break;
case 7:
// go to hall 7
break;
case 8:
// go to hall 8
break;
finally{
finish();
playgameB.start();
@Override
bclick1.start();
@Override
bclick1.start();
//Menu code below
return true;
case R.id.restart:
return true;
case R.id.options:
return true;
case R.id.quit:
finish();
return true;
return false;
here is the start activity code in the previous class
and the activity code in the AndroidManifest.xml
<activity android:name=".hallOne"
android:label="@string/app_name"
android:screenOrientation="portrait">
<intent-filter>
<action android:name="com.brggames.dquest.HALLONE" />
<category android:name="android.intent.category.DEFAULT" />
</intent-filter>
</activity>
