androidfear93
I'm trying to get cyanogenmod 7 on my phone but since stupid rom manager doesn't support my phone, I have to do things the hard way. Can someone help me out????? Like how do I get clockwork recovery on my phone?
Cm7 won't work but cm9 will??? That makes no sense
Well I tried to install the clock work recovery to get it out of the way, but I hit a brick wall towards the end of the process, it says to launch the command prompt from the originating file. But when I type "adb shell", it says it cannot be found or doesn't exist, I have adb installed, any ideas??
Well most websites regarding putting cwm on the exhibit had this process. Idk maybe its a different thing. But so if I update, all it does is it makes my recovery mode cwm? And my current stock rom will have nothing deleted off of it?
It worked, I now have cwm recovery on my phone. I have one last question, can I use rom manager now considering my phone is flashed with their stuff?
Yea I already checked that out, bummer. But so im gonna try out the cm9 beta and ive already made a back up. So the options I hit before I hit "install from the sd card" is "wipe cache partition" and "factory reset" right? And then reboot?
