SpiritOTG
Hello everyone, I do believe I have officially broken my phone, however, something tells me I shouldn't give up quite yet.
My cool-story lookin ass decided "Gee, I have done a lot with my phone, and I really want to try and use Cyanogen Mod on it because I am cool!"
Well, I am definitely not that cool. It failed, and then after sadly being turned to my stock ROM, I decided to try Clockwork Mod, it seemed that some were doing it quite easily, so I attempted this myself.
Another failed attempt there, so I figured, well, the Clockwork Mod app had some cool stuff to it, maybe I will just satisfy myself by trying to change the bootup animation to Nyan Cat to make myself feel better about it.
The original purpose of me flashing a ROM over was to allow me to install apps to my SD card without having to go though a Myriad of things. Turns out, that was probably the better option.
Allow me to tell you the current symptoms, and let you know what methods I have tried.
Methods I am trying but have so far had no success with:
What I can do
Get it to the Download Mode screen.
So far I have tried these methods with and without both the SD Card and SIM card.
The phone IS out of service right now and I did soft-root it at one point using Ngyuen Root method King User, so I don't believe I will get any support, even if I do take it into Sprint (Got it through Boost Mobile).
What I am thinking I may be able to do (no research on this yet)
Is be able to run Linux Distro Ubuntu, force wipe it, and then force the stock ROM back into it to make it run again..
But so far, I have mostly broken down far and needed to post a thread about it here.
If any of you have any suggestions as to what I might do in order to get my phone back up and running (loss of data is irrelevant and already happened) again, that would be fantastic.
Much appreciated everyone.
- Stuck on LG boot screen, does not load OS
- Now no longer will power on or even try to without being connected to my PC (not sure how that came about)
- Recovery (Power + Vol Down) does not work, freezes when telling me to wait (gave it a good 30 minutes)
- Factory Reset does not work (freezes after second confirmation gave it about 30 minutes)
- LG Support Tool - (Tells me it stopped working at the beginning of the 3rd step in Upgrade Recovery) (I am letting it sit right now and is still there after about 20 minutes or so)
- Unsoft Brick (OneClick Unbrick Java tool) - Flat out fails.
- The Connect.img for VMWare fails ultimately
- KS360 Util ENG (So far no luck. It crashes douring the upgrade.)
- LGFlash Tool - I got it to say Ready and then boom, I unplug and replug in (as per instructions) and no dice, I get no "PASS" on it.
What I can do
lease edit your post to Solved
