Hello there! I was finally able to root and install a custom ROM thanks to your instructions and helpful advice (here is the original thread http://androidforums.com/ascend-all-things-root/714772-urgent-help-dumb-question.html#post5786050 , I know its been a while. This ROM is great however a few issues arose and I am going to post them separately as I am sure that it would help others right on the tittle who might be experiencing the same problems with this ROM and who could benefit from the same solutions or work arounds (if there are any).
Well, as the tittle says I have no home button!
If I want to go back to the main screen/Home screen/ Main Menu/Launcher (whatever it's called) I have to press the backwards arrow on the bottom of the phone repeatedly until I'm finally back at the main home screen. This is a major inconvenience and loss of functionality compared to the stock ROM yet I would keep it because of the gains though I am positive that this is not how this ROM it was meant to operate.
I went through the settings to see if there was a way to "tune up/personalize/customize" the interface but found nothing relevant.
I have two exact phones rooted and loaded with the same ROM both going through the same issue!
Please help!
Thanks in advance for your advice!
Please help!
