Root [solved] HTC stuck at LOGO screen while installing custom rom..please help :(
am a noob in installing custom roms and stuff..My htc desire hd is S-ON, Rooted but the bootloader is unlocked..
i am usking TWRP custom recovery
i tried to install a custom rom(Blackout ICS incredible)..i first flashed the rom using custom recovery then i got into fastboot and using cmd while my phone connected to computer i flashed boot.img using fastboot flash boot boot.img
then also my phone is getting stuck at htc green logo
i dont know what to do..this was my first time of intsalling a custom rom..please help me
after that i tried to wipe out the full system using custom recovery only..i had previously created a backup of my system but the backup is not restoring ..what should i do..pleaaaaaaaaaase help me..i dont want to loose my phone
now i have abdolutely no OS installed on my device..my parents wont buy me a new phone after this..please help
make sure you have pulled the boot image from your rom,placed it into your fastboot/adb folder.
then try the process again:
-wipe
-flash rom
-flash boot image
make note if there are any errors on the phone screen,or in your command window.
in order to restore your backup,you will still need to flash the matching boot image.
this link is in the rezound forum,but the info applies,you will just need to use a recovery that is specific to your DHD. http://androidforums.com/rezound-all-things-root/499172-how-manually-flash-roms.html#post3933400
i personally would recomend ext 4 over twrp (you can find link to an ext 4 inage in this thread: http://androidforums.com/desire-hd-...-how-unlock-install-recovery-root-htcdev.html )
i have pulled out the boot img from the rom and i flashed it directly..what is fastboot adb folder? i had 3 files present with my boot.img file i.e "adb.exe" "AdbWinApi.dll" "fastboot.exe"
The link I gave you should tell you everything you need to know about s on rom flashing.
Also make sure you're giving the phone at least 15 to 20 minutes to boot before you pull the battery. The first boot on a new ROM is always considerably longer
Sorry for the short answers, I'm at work at the moment
