For the last couple of days any mp3 that I load onto my s3 (i9300, rooted, checkrom v6) is mysteriously doubled. For the first hour after uploading it will show up as one mp3, and then all of a sudden it is doubled. Both these files are playable too. Is this a JB bug? Anyone know how to solve this?
I'm using the n7 player, but the stock playershows the same problem. The weird thing is that when I use a file manager to look at the mp3's in the folder, all the files are singles as they should be.
Anyone knows whats going on here?
*Edit: Solved*
For anyone who encounters this problem: it's a Jelly Bean bug, doesnt just happen with mp3's, but can happen with any media file like pics and ringtones. The solution:
1:Clear data for 'Media Storage' (in the app manager)
2: reboot (it will look like you lost all your files. You didn't. Proceed.)
3: Unmount ext sd card, wait a minute - mount again
4: reboot and all should be good
*Edit: Solved*
