Help (Solved) SD Card troubles
androidfear93
So yesterday my sd card got damaged and I had to wipe it. Now whenever I plug my phone in, it shows my card but only shows the lost directory file. No downloads file, android, pictures, etc. All of those files are gone now but how do I get them back? Obviously I don't mean the content that was in them but the files I mean. I never created them so I don't know.
If your SD card is damaged u should try formating it, uwillloseverything saved on but eighter way it all gone, if this doesn't work then it is time to get a new 1
20$ for at Walmart or cheaper depending on your location
Or cheap off of Amazon or local Salerno on craiglist
Stick to a 2 gig SD card because most may not support your phone
I had a 8 gig card that worked on my phone. I formatted it, it works from what I can tell, my problem is when are the android files going to appear on my sd card like they did the last time?
