Root [solved] xRecovery keeps saying "File system is read only?"
DbzDashie
I am trying to put Feralabs rom on my X10, but when i get to the part of installing xrecovery, it says on the three files when i click install and it comes up with 3 red circles with crosses through them
cp: Can't create '/system/bin/chargemon': File exists
cp: Can't create 'system/bin/busybox': Read only file system
cp: Can't create '/system/bin/xrecovery.tar': Read only file system.
I have busy box installed and i am for sure rooted, I have rooted it with flashtools and it says it is rooted, a root checker i downloaded says it, titanium backup says it is,and connectbot shows it is. So i cannot figure out why in the world this won't work, Unless it has something to do with the phone being ATT, because i can't change the installing from unknown sources on it. But i installed xRecovery from flashtools so...Can someone please help me with this?.
Thanks, I solved it by downloading a custom flash tool that installed xRecovery for me :), I am not on my pc at the moment so when I get on it later I will see if I can fine a link..
