yogurtpooh
1) Is there anyway to show the percentage of my battery life right on the battery itself on the top home screen?
2) Is there anyway to shut off the noise of the start up screen when the Android 4G appears?
3) Is there anyway to turn my phone back on aside from the top right power button? - Can I use the home button somehow?
4) Is there anyway to silent the phone with a swipe like on earlier android versions from the lock screen instead of having to unlock it and then using the profile widget?
5) Can I remove the vibrations from my keypad but keep them on for the three "hard" buttons on the bottom?
6) On the old Android system- the keypad automatically spaced after a word. On this device, after selecting a word as I type out a text- it does not space itself.
7) Is it recommend to add some kind of lens protector for the back camera like on the front screen?
THANKS!!
THANKS!!
