Help Some complete noob questions
Technologx
How do I deodex my phone or do I even need to, to install a rom/theme? I mean I've been trying to install the Dragon rom by Team Var and my phone won't go past the htc Powered by android screen. Also is there a rom for Boost Mobile HTC Desire 510 phones or kernel for lollipop? Also I'd like to know if I need to re-lock my boot loader?
Most custom ROMs are deoxeded already, and if you want a deoxeded rom the easiest way is to install one rather than deodex one that isn't (you'll find descriptions of how that is done on the web, but I've never bothered).
You do not need to deodex to install a ROM. Since deodexed describes the way the rom is configured, and installing a new ROM replaces it completely, that just doesn't make sense. Theming is much easier with a deodexed rom - probably the main reason people do it TBH.
So your problem is most likely a bad ROM download or some problem in installing. Is the 510 one of the devices where you need to flash the kernel (boot) separately after flashing the ROM? And if so have you done that? Did you do a factory reset before flashing (if not that will also cause this symptom)?
You don't need to relock your bootloader unless you want to flash an RUU. I don't know about ROMs or kernels for thus specific model, so can't answer that last. See whether we have anything in our device forum for this phone, or else have look at XDA.
Every rom that I've looked at said do not factory reset only wipe davlik cache & I just can't seem to find a rom I like. I was hoping to find a guide to teach me how to do this android theming I use to theme for iOS.
Wiping cache and dalvik are the minimum, but if there are any significant differences to the base OS or system apps a factory reset is a very good idea. It also depends on what ROM you are coming from - if you are installing a near stock rom based on the same OS version you are already on then you'll probably be ok with just a cache/dalvik wipe, but if you install the same rom when coming from something more different you likely will not be. So if it won't boot, you've checked the download is good, you don't need to separately flash the kernel, and you've followed all installation instructions correctly, you are using a recovery which is known to work for that ROM and you have the right device version (some carrier versions can need different ROMs), if all of that is OK but it still won't boot and don't want to just give up and try another ROM, then it's worth taking backups (nandroid and app/data backups), doing a factory reset from recovery (cache, data and dalvik) and then installing. If it doesn't work after that then something is wrong, in which case restore your nandroid and try to identify the difference between what you've done and others. But if you've not tried a clean flash (i.e. after a reset) it really is possible that that is your problem: some system data that is not compatible between ROMs prevents the phone booting.
As for theming, some ROMs have their own theming support built in (e.g. Cyanogenmod's theme chooser), others you have to do by hand, e.g. editing Framework-res.apk and SystemUI.apk (which means the mods only work with that ROM), so I would choose the ROM first (I'm not a theming expert, though I've done a bit for my own use in the past). Obviously stuff like icon packs and launcher themes you can do without root, so I assume you are interested in theming the system UI, notification bar, system apps or similar.
Right now I'm on a stock rom looking for a better looking rom. I'd like to learn to do my own like with creating apps to go with it to like a launcher and set up app. But I have no idea how to make a app.
