Some general questsions after rooting phone and Installed game having error when booting
redeem4
Ok, so I successfully rooted my phone, so what now? Any specific things you recommend for me to download or anything that I need to get for the root to do more things like custom themes or to install games?
I have downloaded the UCCW and a couple of themes to go with it and when I try to load the themes in the program, it doesn't recognize any of them and just tells me to download some themes from the google app store.
I also tried downloading a game, final fantasy v to be exact, and when I found the file via File Manager and installed it using one of the preinstalled installers; It installed fine and when I went to play the game, it was unable to play the game. Now this could just be the game itself, but then again...I'm not sure
Thanks for the help in advance.
What i do is disable all of the bloatware using root app delete... Installing some adblock is also a reason why i root. Right now there are not themes for this phone but you can install launchers and icon packs that are better than the stock ones..
ok, thanks. Well how about installing games? If I can even do that.
