Root Some Goodies to flash :)
Cooper271
Thanks to all of the hard work on SDX, they've made a deodexed template and a template with some goodies.
If you haven't already create a folder on the root of your SD card named sdx.Within it make three folders backup, update, zip. You'll put these in the zip folder.
You have to do this one first. Make sure to clear the dalvik cache!
EB28 Stock theme template (deodexed)
Then this one.
EB28 Mods - 5% Batt, Reboot/Recovery, No Vib on Shutdown, 3G, No Full Batt Popup
They both work great.
You need to be rooted with custom recovery, check out this post http://androidforums.com/samsung-transform/307457-guide-custom-recovery-root-2-2-guide.html
EDIT: Just looked a little more. They're adding power control to the drop down notification menu, then themes and ROMS will start to be ported.
