Help some issues with my S3
LoayBal
Okay, I've got my S3 from 3 network in the UK, and I have some issues with the phone and I hope u guys have some way around it.
1- Is there a way to link the contacts automatically across the contact list (i.e. the same persons's different accounts on facebook, twitter etc.) just the way HTC sense does it.
2- I've put the massages and email apps shortcuts on the home screen and whenever I get a new massage or email I get a small number on the corner of the app shortcut on the home screen, but the problem is that small notification number doesn't go away even after I open the massage or email, and doesn't go away until I go to the task manager and clear the ram.
3- the camera's face tagging used to work fine when I first got the phone, but just today I noticed a problem with it. When I try to add a name to a new face in the gallery it just doesn't show it, I click on the face tag then I go the contacts to add a name and after I choose a contact and go back to the gallery the face tag is still unspecified!
Is anyone else in here have similar problems with their S3 or know a way to fix these issues?
Many thanks in advance
thank you all for your helpful comments :o
anyways, if anyone is having similar problems to what I described in my post just do a factory reset and it might work fine. I did a factory reset couple days ago and it has been working fine ever since
Hello mate
On my other post, basically, all you have to do to get rid of the red notification bubble, is you have to press and hold the icon with the notification, ie on mine it was the messages and phone. Then drag them to the trash bin. And then find them in the APPs and put them back and the notification should go away! No need to factory reset.......
Hope this helped!
Sg
i am facing the same problem and did try the factory reset however the issue is still there, i have logged a complain with the samsung customer care lets see if they can help...
same problem here only thig thats work is to take it out the descktop. In the main menu the problem is solved (no more new bubble appears) even when i get a new one it disappear after opening it...
