Hi guys, I bought a second hand g1 and have found that about 5 of the letter keys do not respond to being pressed. How can I do the initial google login?
Thanks a lot.
Open the keyboard as it tells you. Then close it. When you select the username or password fields, a virtual keyboard will show up on the bottom. Later on you can figure out what is wrong with the keyboard.
