Hi, figured I would take a shot with you folks to see if anyone has a solution. I have a GS3 on Rogers in Canada (same phone as AT&T version) and have a couple of minor issues.
Since the latest firmware update a few weeks back my S-Voice will no longer work when connected to bluetooth in the car. The S-Voice screen comes up but the mic button onscreen doesn't turn to blue like it normally does when listening. If I use the phone without bluetooth then S-Voice works as normal.
I also connnected it to a BlueAnt S3 hands free unit via bluetooth and it worked fine so seems to just be a new issue with my bluetooth in the car. (Subaru Impreza) It did work fine in the car before the update. (at least as fine as S-Voice normally works....)
Also, I have a 4 digit passkey on my lock screen and have the phone set to enable auto-lock after 10 minutes. However, EVERY time I make or receive a phone call, the lock screen engages again immediately after the call even if the call was only 20 seconds long. Highly annoying in the car when I have to keep unlocking the screen.
Any ideas? Love the phone otherwise and appreciate any feedback. Thanks!
James
James
