Help Some problems (Or maybe there not)
Mrdroid921
Android Expert
I have haptic feedback turned off, but the arrows you use to navigate the
home screen still vibrate, as well as the luck buttons and widgets. Is this
normal, or is this an issue??? Also while in low light, or dark conditions,
shouldn't the for hard keys light up?? Is this an issue if they don't, or
just an affect of not having brightness set to auto?
Thanks for any help.
if you notice the haptic feedback setting says "on certain UI features", and as far as the keys, when you press the power of home button they should light up, however i have seen an issue on my gf's DX where they occasional stayed off no matter what which required a reboot to fix but she was running the leaked 2.2, no issues since offiicial release.
So even with Haptic feeeback off, there will still be some vibration
no matter what?? When you have yours off, does it still vibrate
for the lock screen and the arrows for switching the home screens??
yes i have me feedback off and still get some vibration for power off, and some screens, just not every single thing
