Infiltrator
Hello, I am using a Samsung Galaxy S2 (in case it differs from other android devices) and I had some questions regarding icon placement.
1. If I make a folder, and want to rearrange the icons inside it, when I try to drag icons they automatically pop out of it and I can only place it outside the folder.
2. If I want to link an icon from a folder to my main screen, I get prompted to put it outside the folder, in the app screen instead. I know I can manually put the icon by listing through all my apps but I was just wondering if I can do it the "easy" way.
Thank you.
Thank you.
