1. I know Phone Info will allow me to shut off 4G and run a strict 3G device. Has anyone confirmed this is worth the effort and will save a noticeable amount of battery?
2. -SOLVED- I used to use an app called Y5 on my other droid phones, it turns on wifi whenever in range of a saved network, it turns off wifi when not in range. Im not seeing it working on this GS3, is there another app or method i can accomplish the same thing?
3. When i get a call or msg, the ringtone plays through the phone even if im wearing a headset. Is it possible to only play it through the headset so nobody else can hear my alerts?
4. The last few days I have been monitoring my battery usage and find that actual phone calls are quite a heavy process. Is this due to the dialer by any chance? Maybe if i switch to maybe Dialer One, will it possibly be a lighter process? I don't understand why the phone calls are weighing so much on battery life, i've never experienced this on my other android phones.
5. -SOLVED- In the past I have successfully used an app named JuiceDefender which saves battery by turning off all data for like 10min, then turning it on for 1min to allow for syncing, then off for another 10, and on and on. Would this app function properly on this phone even with the 4G network? or is it useless on this device?
6. -SOLVED- Has anyone tried the new 3500mAh extended battery, or seen any reviews? Id like to see how big this bish is when all setup. I LOVE the idea of extended battery's and have always gotten onefrom Seidio in the past and had excellent results, but this is my first larger screen phone and im not sure if i want it large AND thick. (dont touch that one lol)
7. Can i shut the shutter sound from the camera?
8. In the "Location Services" menu in settings, is there any advantage to shutting any of those 3 off? Right now I have all 3 enabled constantly.
9. regarding "Mobile Hotspot". I am wondering if this can be left Enabled at all times? Obviously if it impacts the battery I wouldn't do it, but im wondering if maybe the battery is only impacted only if/when the hotspot is actually connected to and data is being used. Can anyone confirm?
10. When im walking around the street i often get alerts of available wifi networks. On old phones i was able to turn this alert off, but i cant find the toggle on this device. Can anyone point it out?
Thanks, i think that's all i have right now. Any replies would be much appreciated!
