Some small questions about x10 mini pro
Gexas
I have bought Sony Ericsson x10 mini pro recently and I like it, I like it style, it size, it working speed, but now then I used it more I left pretty disappointed by UI, more I use it more questions I find. So please somebody help me answer these questions:
1. How to install app to sd cart, not to phone memory?
2. Why in my music player are sound from some games? How to remove them?
3. How to delete trash icons, because till I bought phone there are many icon which I don't need, so it just taking place and making a mess.
4. How to create folders to manage my icons and add some order in that app mess?
5. Is it possible to delete few contacts from phone book in one time?
6. is it safe to use phone LED as flash-light?
Hello there I will try and answer what I can...
This function is only available on Android 2.2, we are currently on transition from 1.6 to 2.1, no information has been announced about when/if we will get 2.2.
Sorry don't know - hope someone else can chip in with that.
You can't remove preinstalled applications unless you root your phone.
You can rearrange your icons in your app drawer, swipe up to open it and then press Menu and then arrange icons. You can drag them to where you want and move all the ones you won't use to the end of the list.
I would think the easiest way to deal with contacts is to do it on the pc having used either Google sync or Sony Ericsson sync to upload them and then resync to bring them back to the phone.
6. is it safe to use phone LED as flash-light?[/QUOTE]
I use an app called Colour Flash to use the screen as a flash light.
Hope some of it helps.
Thank you very much, your info is very helpful. Now I have another additional question :) is it possible to lounch flash on this phone?
I think flash (in relation to viewing on the internet) is only available from Android 2.2 so again we miss out on that at present.
- only available on froyo android 2.2 OS
- when you launch the music player it pre loads all the music files on your SD card. there seems to be no way to filter it. the best way to deal with this is by using a playlist to select your favorite music files.
- rosered is right, there is no other way unless you root your phone.
- just drag and drop using the arrange icon.
- aside from using sync, you can try downloading "contact remover" app. this allows you to tick multiple contacts then delete it at the same time.
- if safety is your concern with LED, it is very safe. just don't use it for a prolonged period of time it drain your battery. :)
hope it helps.
